1 - 2 of 2 Posts
I have media blasted, primed and painted the main hub on my CL200 front wheel.
The dang thing looks SWEET!
However, I can't figure out how to remove the spiral-cut speedo drive gear in the brake backing plate.
I have (prematurely) blasted the plate, but now I obviously, need to remove that gear.
I have diligently looked for a circlip or something else that holds the gear in place but can't figure out how to remove it.
Any and all suggestions are greatly appreciated. :cool:
Jim
Jim, the seal holds it in (along with the cross screwed cable end), and on some models, there is also a roll pin inserted from inside the plate.... remove the cable (duh) and pull the roll pin IF present, and simply pinch and pull with needle-nose pliers on the drive flat..... Should "pop" out, but comes easier if you remove the inner gear that drives it....(careful, there's a thin thrust washer in there, get it out too....)
I learned all this playing with the speedo drives for the CB 200 disc wheel (and others) on the 90.... Thought you'd appreciate that..... ;) Steve
1 - 2 of 2 Posts
