Discussion Starter · #2 ·
A couple of us here are needing those handlebar damper bushings. I contacted TAZ about a week ago and he said they actually only have two in stock. He said he's let me know when they arrived. He has to import them apparently. So anyone ordering should be prepared to wait on them if you ordered more than two. How long could be anyone's guess...
Also, as mentioned by another member here, the bushings will likely require some finaggling to get them to fit, being aftermarket.
Might be worth to explore past MSN posts (as provided by Ted) because someone (the name escapes me) found a
very usable handle bar bushings at a local plumbing shop! as i remember, the shape and size
had them fitting right in. if this was you, and YOU know who you are har-har., then please chime in! danWI
They do make a plumbing bushing that looks close. Goes over a I believe a 3/8 flexline with a nut over that to compress the rubber tight to the flexline. Not sure how durable they would be for handlebars though. I might take a to my Local MX shop and see what they have for generic.
