One of the things that popped up when I tried using the electric starter on my recently acquired '70 450 is that the starter will turn over a few times then sounds like it's grinding or skipping teeth.
Are starter problems common on the 450's? Do the clutches go bad or maybe some broken teeth somewhere in there?
I'd rather not pull the starter right away since I want to work on the compression issue that I outlined in my Projects post, but I thought I'd start asking questions so get some opinions.
