If anyone is looking for new fork gaiters for a CM400 I found very good ones that fit & look perfect on Ebay. The seller is 'Horsepower-House', 'bikebrokeratl' in Marietta GA. , and the item number is 201962841657. "33mm Rubber Fork Boots Gators @ 34mm Forks - 70's 80's HONDA CB400 CM400 CX500 +" is the title. These are the exact correct length for my 1981 CM400, and the small end and large end fit perfectly on my upper and lower fork sections. Soft, pliable stretchy real rubber, not hard cheap plastic like some. $35, kinda expensive, but still way less than from the stealership. They went on easy and look great! And provide that great classic & retro look w/protection for the fork seals. Check out the pix:
