1 - 2 of 2 Posts
I have a sl350 honda and need to pull the generator out. Does anyone know the bolt size and thread of the threaded hole in the generator? I assume that you thread the puller in and it backs the generator off the shaft. Or do yo thread it in and the puller has a weight on it and slam it off the shaft. Anyone ever done this? thanks
The CB 350 rear axle has the correct 16mm thread (not positive about the SL)....Thread in until tight..smack the bolt as you try to tighten further...Rotor will pop off the taper... 16mm JIS thread
1 - 2 of 2 Posts
