Hey guys, been considering upgrading my CL360 gauges to a single needle tach with a digital spedo. In particular I'm looking at this one, link https://www.dimecitycycles.com/acewell-ca085-551-classic-multifunction-12k-tachometer-black-cnc-white-face.html I also plan on buying the conversion spedo cable, link https://www.dimecitycycles.com/acewell-digital-speedometer-conversion-cable-for-honda-cb-cl-yamaha.html so that the connection is easier. Being a conscious buyer I went ahead and took a look at the manual before I even thought of purchasing linked here, http://www.acewell-meter.com/wp-content/uploads/2016/01/CA-085-1XX_2XX-Series-V01-USER-MANUAL-EN-20150211.pdf , and I've run into several questions.
1. On the second page under the Wheel Circumference Table on bullet point 5 it mentions that if i am using a cable drive speed sensor, which I assume is the conversion cable I linked above, I need to enter in the number of turns the cable makes per turn of wheel into the pulse screen. How on earth would I even begin to find this value as wouldn't the rotation be internal, i.e. inside the cable where I cannot see the rotation?
2. Under the Clock, RPM, Wheel, Divider, Unit, Maintain etc. heading bullet point 6 it says, "It displays "RPM SP 1r1P", the default value is 1r1P; there are 5 options: 1r1P, 1r2P, 1r4P, 2r1P, 3r1P, “r” means the numbers of engine rotation, “P” means number of signals from engine. For example the value 2r1P means the engine rotates 2 turns to output one signal." Once again this is confusing, or perhaps I am over thinking it because on first glance I believe it would simply be 2r1P; please add any insight / correct me if I am misinformed.
3. Under the previous heading bullet point 10 it mentions different speed sensor type settings. Given that I am using the conversion cable my setting should be the gear sensor one as I am not using any rEED or HALL magnets, correct?
I understand this is all a little tedious, but any insight would be appreciated as I am wondering if this gauge will even function properly on my machine. Thanks
