Hey guys,
71 CB 350
I searched the posts for gas tank holes and repairs, but they were all rust related, and my problem is that the underside of my tank has "crinkles" to it - which is weird because aside from a few dents in the tank it's not like it was smashed and straightened.
I do have a 2nd tank, and it has crinkles too, although not as bad. Is it possible these "crinkles" are out of the factory? It seems really unlikely.
Anyway, the problem is that it looks like the crinkle under the tank has been in contact with the sharp ridge of the top of the frame and vibration has buzzed a hole in the tank. It weeps fuel when I fill the tank more than half way and my garage smells like it's about to ignite.
I tried cleaning it up and using JB Weld to bond the hole, and I took a grinder and removed the ridge-tang from the frame where that crinkle is, but it's weeping again.
Any suggestions on how to best repair this single hole? I don't like the idea of brazing or welding, as I've never liked the notion of blowing myself up. Or should I scrap the idea and go with my other gas tank?
I have a 2nd tank that I am stripping down but I like the one I have now, it has a beaten patina that I like (I bought the bike with the tank stripped down to bare steel and was planning on painting it, but the more I look at it the more I like it, and am going to keep it bare metal - I keep it clean with fine grit sandpaper and keep Honda polish on it, and surprisingly it does not rust over even here in GA).
71 CB 350
