1 - 1 of 1 Posts
Hey first time posting. I just bought a '73 cb350g "barn" find. I had little hopes that the gas tank wasn't going to leak, and sure enough it did. It has some surface rust, inside and out. The inside is pretty rough, but I'm sure it can be removed if I could just get the tank not to leak. It has a few different areas. One on the bottom front seam, one under the honda emblem, and one on the underside. The seam leak is a decent drip per second while the other 2 barely drip out. I guess since I'm new to all of this I'm wondering if it's worth fixing or do most of the time you scrap it and find a better option? I'm great with mechanical issues, but when it comes to welding/epoxy/etc I'm a novice. Any help would be appreciated!
1 - 1 of 1 Posts
