Gang,
I am de-rusting my tank right now with Evaporust ... I saw a post somewhere where someone referenced coating the inside with Marvel Mystery Oil to prevent flash rust ... curious, do you just pour the oil in the tank and swish it around? What's the best way to apply it? Also, will it gum the works up after putting gas in the tank?
Anyone use this stuff? Thanks Bill
Pretty much any engine oil will work. Some would recommend 2 cycle oil since it mixes readily with gasoline and, in small quantities, can pass harmlessly through the fuel system.
Put in a cup or two, swish (swirl?) it around and drain the excess.
marvel mystery will also mix with gas so that isn't a problem. Just pour some in and swish it around to coat the inside.
