1 - 14 of 14 Posts
Does anyone have a source for the OEM style spring clips? They look like this:
There are a couple of suppliers in the US, but they're charging about $2.00 each. I need about 10-12, and it's really not the money. But it's the money, you know.
Check with you local honda dealer, mine gave me several for free that were used.
That's a great site, but they don't have a match for the OEM style. It's close, but not quite.
I threw some in the trash today still on the hardened original fuel lines if you want some with real patina
Reactions: ancientdad
That's the right style. But $1.50 each?! That's just nuts.
I wasn't going to call them out, but David Silver Spares has them for the same price (after shipping). I just can't believe that they are so difficult to find that I'm considering spending $20 on 10 tiny little clips. I mean, it's just $20, but...
This bike is nickel and diming me to death.
A lot of people don't even use them but I won't take the chance.
...This bike is nickel and diming me to death.
Welcome to the club. I've spent quit a bit of small change (which eventually adds up) on small, correct parts. My bike will never be 100% correct, though, so I cheaped out on fuel lines - I used 3/16" gas line that's such a tight fit on the brass bungs that clamps aren't needed.
Discussion Starter · #13 ·
No, it's not even close to concours. And I appreciate that it's a bit neurotic that I care this much about a fuel clip when many, many other things on this build will not be anywhere near original. I can't explain it. :shrug:
I gave up and decided to go with the moose racing wire because 4into1 says it'll fit.
I had the conundrum of 5.5mm line from the Ape 100 tank petcock going to the 5/16" lines going to the Mikunis, and it took me a lot of research and driving to find a hydraulic hose repair facility that could match up brass fittings to step up from the smaller line to the larger. I only have the OEM wire clamps on the 5.5mm line for a factory Honda look... but honestly, no one even notices :rolleyes:
1 - 14 of 14 Posts
