well this sucks, i was changing (trying) the fuel lines on my 450, one side went fine, the other side when i pulled and pulled the tube from the carb, the inlet nipple came with the tube....
:eek:
so i tried sticking it back in as best i could, but now there is a slow leak coming from it at all times.
can i replace this thing? i damaged it slightly with pliars trying to get it from the tube,
is tehre some way to seal this back up?
thanks
I've smeared a thin layer of JB Weld on them in the past. They never came out after that.
I used the fast drying type and kept it away from the end so as to insure none moved down past the end of the tube.
JB Weld sounds like it's worth a try.
For future reference, if you use one of those long-bladed hobby knives and cut a slit up the side of the fuel line (or vacuum line for that matter) it comes off a lot easier. Of course then you have to replace the line but that's a good idea anyway and it's cheap.
When I'm removing a stubborn fuel line I use one of these 90 degree micro-picks, and just slip it under/into the line and run it as far around as I can while pulling on the line gently. Harbor Freight tools has them for cheap..
give it a light tap to seat it after the JB they were just pressed in to start with
If the tube is chewed up, try taking the carb/tube to a hobby shop that specializes in powered models. They may be able to supply you with a replacement for the tube that will fit tightly. I had one come out once, but I was able to just press it back in - I put a piece of soft pine over the tube and tapped it lightly with a hammer - and it fit tightly.
