I am sure this has been beaten to death, like in dead horse, but I sat in front of my bike and studied the forks and wheel and it seems like wheel alignment is not needed. If, the frame is straight, the triple is not damaged and the forks are OK the alignment should be OK.
There was some talk about loosening the triple clamp bolts and the axle nut, spinning the wheel and hitting the brake and everything would go into proper alignment??? The fork lowers are free to rotate on the upper, if the axle slips through the lowers and through the wheel it should be OK??? What am I missing???
