IIRC the piston bore for the 450 master is 14mm. They switched to the dual piston calipers in 1981. My 79 CM400T and 1980 CM400A both have the single piston calipers.
So the master should be OK. The caliper on ebay is used on several models that year. The price is a bit rich, I think. Don't know about the bracket, though.
You should have the stock 2 piston caliper already. The mounting bracket was also used on these models so If you can find an upgraded caliper that's for one of those it'll mount up to yours
Instead of messing around trying to find a different caliper how about going with some really good brake pads? Granted that the original caliper even on the best of days is somewhat inferior to the 21st century but it does work quite well. Add in a good master cylinder and the SS braided hose. HONDA | CM C | 400 | 1981 | Pads | Motorcycle Brakes Configurator
My bike didn't come with a caliper the previous owner...idk what his deal was it came without alot of parts so that's why I'm trying to do my build as budget friendly as possible
Bracket I ment...no carbs ether...I'm gonna pick up some mikuni carbs from speed Moto Co...also some GENIUS decided to WELD the gear selector to the rod which broke off we got the piece of gear selector off now it's got weld pooled into the teeth of the rod so that's another can of worms.
I have a caliper here, no mounting hardware at all. Spread between the mounting holes is 74mm. Pistons are boogered so it'll need new pistons and a complete refurbishing.
