I feel like the default answer is rightfully "no" when someone asks if they can use some old, rusted, pitted pistons...but I'm going to ask this anyway and hope that I'm the exception to the rule 😋.
This is on an '85 CB450SC with the dual piston front disc brake. This bike sat for about 6 years so I figured it was worth pulling it completely apart and assessing everything in the brake system. I was able to get the pistons out using a method similar to this video on YouTube since I didn't have an appropriate air compressor attachment to do it (basically using a master cylinder to push them out gradually; I used the one on my bike). One thing I did not realize for a bit was that I really needed to keep the bleeder valve on the calipers as high as possible (relative to the rest of the caliper, but below the bleeding kit/vacuum thing) to get all of the air out of the system, as well as tapping the brake hose for good measure. Eventually I got enough pressure in the system to push out the pistons.
Anyway, here are the pistons themselves. I cleaned them with brake cleaner and then some Barkeeper's Friend. (Side note: does anyone else use BKF to clean motorcycle parts? It's a powder with oxalic acid in it and is super gentle on pretty much any surface, but does an amazing job at getting rust and grime off with a little bit of water and elbow grease.)
The left piston seems fine, but the right one has some small pitting on it. I have some random aftermarket (I think) piston I bought years ago that's basically new, but the thickness is noticeably smaller than these (I think OEM) ones, so there's always the option of using that.
