I noticed my front end was making a clunking sound. Pulled over and discoved the front wheel is loose. There is a gap in the axle. Am I missing something? How do I fix this? Thanks
Chris -Chris Garrett said:When I say "adjust", I mean I'm trying to get the exhaust to go straight back without making contact with anything. No matter how I twist and pull the header and muffler, the header is making contact with the brake pedal. It just doesn't all seem to want to go in the right place.
No, the exhaust pipes are left and right, mirror images, maybe not easy to see if you're not familiar with them - stock mufflers are obvious left/right, easy to see.Chris Garrett said:I don't know what kind of mufflers they are. Can mufflers be switched? I didn't know the headers could be switched. I thought they were the same. I'll try again tonight to make it all go together.
Simple is good - just ask any 70's SOHC Four owner if they'd like simple carbs........Bird76Mojo said:Don't worry. The carbs are unbelieveably simple once they're C-L-E-A-NThey do work very well if properly serviced and synced. Bill seems to be a huge fan of them..
