i found this hanging off the front. the wires come from headlight assembly. wear does it screw in?
If the PO cut the harness to install inline then yes, if they added a circuit to the flasher then no.If i want re remove it. i cut the wire and splice them together?
Oh, the cacophony. Imagine a ride with a dozen or so bikes, chirping away at a stoplight like cicadas. Next time, tell that arse his blinkers are on and be done with it!I really think it is about time that signal buzzers were made compulsory for bikes with indicators. So many times have I ridden for miles behind a bike indicating a turn and dreading to see a driver believe it and pull out in front of him.![]()
Clearly Mr. C Chicken has never seen properly installed warning sounders. If wired correctly they should be muted if the clutch is pulled in and/or the bike in neutralOh, the cacophony. Imagine a ride with a dozen or so bikes, chirping away at a stoplight like cicadas. Next time, tell that arse his blinkers are on and be done with it!
