I'm replacing the ball steering bearings with roller bearings. My issue wih this is that the stem does not protrude through the upper bearing enough for the nut to thread on (threads are not visible). I discovered this when trying out the length prior to mounting the lower race that goes on the stem on the lower tree. The upper race in the neck is pressed all the way down in its seat, so that's not the reason. The bike is a -82 CM400T and I'm pretty sure the tree is the original one. It did fit just fine with the ball bearings.
Any advise from any of you guy's?
