A while back I posted a question re: the ability to remove the cylinders with the engine in the frame. Somone (Bill or Steve?) posted that the engine needed to be removed.
I wanted to follow-up and confirm this is a correct statement. My Clymer manual talks about removing the cylinders and the description makes it sound like it can be removed with the engine in place. It says, "remove tank, remove cam covers, plugs and cam master link. Remove head nuts and lift head off. Later on it says, "remove cylinder head as described earlier, lift off cylinders.
I appreciate all the help all the experienced mechanics provide us noobs here, but I'll be pulling this motor out myself and if I can do it without the cylinders and head in place and also have the opportunity to inspect the cylinders, hone and replace the rings without removing the engine, then I'd like to give that a try first.
Thanks again.
Thanks again.
