1 - 2 of 2 Posts
The stock indicators which came on my cb500 were not in great condition so I have decided to simply remove them since my state does not require them. Will simply taping off the connections be enough or will removing the flashers compromise the other functions of the electrical system in any way?
Thanks.
The only wire you need to tape up is the black that goes to the flasher module....After that, you can remove the module and the signal light assemblies and just leave their connectors loose...
1 - 2 of 2 Posts
