hi, i have a 72' cb450 lights all work, blinkers don't blink. where is the flasher located ? and also, there is a small electrical component hanging down near the horn. is this a blinker relay ? can that be bad ? thanks,
Yeah, that's probably the flasher relay - should have a rubber strap-thingy that fits on a little bracket on the ignition switch bolt.
Gray and black wires. Black wire is hot (after the keyed switch), gray feeds the left handlebar switch, which routes to either orange (left) or light blue (right) flashers.
They go bad all the time.
Yeah, except the exact part is pricey.
You can get a fat round one at the auto part store for $1.50, run the wires to a spot under the seat or somewhere.....
+1 on that...exactly what I did!
