1 - 2 of 2 Posts
Hi All,
I need to replace my exhaust copper crush gaskets on my '69 CB350 and looked in an Athena gasket pack I had purchased a while ago. The pack came with these metal gaskets that look kinda like crush gaskets (see photo below). Can I use these on my cb350? Or should I just go get the copper crush ones from Honda?
Side question: when removing the copper gasket from the head is it cool to use a screwdriver, or would the screwdriver mess up the engine metal?
Thanks!
I prefer to use genuine Honda parts but I've used those and they worked fine. I took a medium flat bladed screwdriver and ground the end smaller then bent it a 90 degrees about a half inch up from the end. I use this to hook out the old gaskets.
1 - 2 of 2 Posts
