I have to direct you to the build section for the pics (rudy's 72 450 cafe' build)
viewtopic.php?f=5&t=5440&start=10
My intent is to attach the baffle to the head pipe and slip the muffler over it.
The baffles is 7" long and I closed the ends off. The mufflers are 12"
I'll be running UIN air filters.
I'm wondering if I'll need bigger jets in the carbs.
I doubt excessive back pressure will be caused. Once the baffles heat up they will open back up if needed. They bend easy now.
Re: Exhaust back pressure - take a look @ my baffle - opinio
im kind of in the same situation. i have the emgo 12" mufflers and pod filters. i had to go up from 145 to 155 on the main jet. but i DIDNT close up the baffle end. got my jets from dime city btw if you were wondering
I'll bet they are LOUD!!
How did you fit them to the head pipe?
My clamps and pipe sizes are not a good match.
used exhaust tape. like the stuff you'd use to cover a hole. or some header wrap i head works well too.
