So I’ve had a minor seeping from the cylinder to head gasket after I had to take it apart and do a lil fix if one of the intake valves. Nothing horrible but annoying. Now that I’ve been in a rider coach course the oil is leaking pretty good today to where you can see the dripping while running,but it’s coming from the front and I notice it’s coming from the head in the area what looks to be where you can see the two inner forward head bolts? Maybe the gaskets/rubber is worn out in the headbolts? Or is there soemthing more I’m missing? What’s a good gasket set to pick up and from where? Good price?
On a side note, I know it was seeping some oil out the cable oil for the tach that was broken when I bought the bike, so I decided to screw in a short screw to see if that helps?
