Hi,
On my bike that is likely a '70 or '71, I have no electricity to anything, the one fuse is good.
I was looking for missing wires in the line going into the key switch, and I noticed a small rounded housing mounted next to the key switch housing, and it has one wire going in and one going out.
It is next to the key switch which has wires going into the back with a rubber boot over that, so this is not the key switch housing, but it is mounted behind it, like an inch away, and I'm wondering what it is, if someone added that for some purpose, or if it is supposed to be there.
Thanks.
Glenn
Don't connect them together, that will turn your signals into four-ways, just leave the wires unplugged. Get a test light and look for battery voltage at the red wire behind the switch, battery voltage at the black wire with the key on.
