Well, pulled the bike out a few weeks back, hooked up the battery and I guess Gremlins got the ole' 400 because now the headlight doesn't turn on and the starter only works half the time, and even then it doesn't work right away. I tested the battery and it's good, any tips where to start? I don't have a multimeter down here either, one of the many things I left in Indiana.
Starter button. Normally supplies power to the headlight. When pressed should disconnect headlight and connect power to starter solenoid.
+1 on the starter button. Red connector in the headlight nacelle is the other component common to both.
PM sent re: FSM
