I have a CM185T with a minor Electrical problem... When I put the voltage meter to the battery cables and or a light socket, I am reading at about 85V at idle and up to 185V when I rev it up. I have tried replacing the rectifier twice and the voltage stays the same. I’m looking for friend here, help please.
That's AC volts you're measuring right?
Like this video? (Yes its an RC51 but principally its a similar system) First part they ohm out the 3 coils, then the important part to you is at 2:20 where they perform an AC output test. It would seem like you have a bad regulator/rectifier, or maybe its connected wrong.
Could you post a few photos and maybe a color diagram of what you've got?
