I have a 1972 CL350 and when the green "neutral" light comes on my bike is in gear; when I shift through the gears to get the bike in neutral the green light goes off. How do I sync the two so when the bike is actually in neutral the green light comes on?
Kirk
The left engine cover that your clutch cable goes into, remove that and the neutral switch is shaped like an avocado and is above your drive sprocket. You'll need to put your bike in neutral and adjust the avocado so it touches the prong when in neutral
