1 - 2 of 2 Posts
Probably you all already know this but I will mention it anyway for those that don't.
The household cleaner called CLR is excellent for removing rust and the white stuff that forms (AL oxide?) when a bike sits for a long time. Won't hurt rubber either. Doesn't take must to get those carbs sparkly clean then flush thoroughly with water to neutralize. Still should use Real carbcleaner for the gummy old gas deposits in the jets.
You can also soak in Vinegar or Pine Sol
I've used a 50/50 mix of either....they both work
1 - 2 of 2 Posts
