Some clarifications:
The part that is being modified (#9 below) is getting "new" tabs that go TOWARDS the hub and engage the "flats" the blue strap points to in Jimmy's pic.....
The excess "cup" part is ground away to clear the rotor......
The axle in Jimmy's picture is in backwards... It must insert from the right side as in the drawing below....
IF you also insert the rotor through bolts from the right side, clearance issues with the speedo-drive itself are minimised......
Parts #1 and # 21 are discarded, and a bit of clean grease will seal the bearings from road debris, (and is easily cleaned/exchanged as needed)..... Only use a little.... If it gets on the rotor having an extra brake is a moot point.....
Simply mount the right side caliper and carry arm as a mirror image of the left side...., You MAY need to rebend/modify the fender mount on the right side......
Obviously, you have to do the "plumbing", and a larger volume master cylinder is recommended....
This mod adds appreciable weight to the front end, so I recommend facing and drilling the rotors to reduce the unsprung weight.......Alloy rims help as well......
