1 - 2 of 2 Posts
Hey All,
Quick question ... I have been disassembling a front wheel drum brake (I believe off of a '72 CB350) and am stuck trying to remove the speedo gear ... wanted to confirm my suspicion that a very small pin on the back side (see photo) is what is holding the gear in place ... any tips on pulling that pin if so? It doesn't want to budge!
Thanks Bill
Looking at the fiche, yeah, that pin holds the worm drive(?) assembly in place. It's part #22 on this diagram:
It appears to be a split pin (with the split running along its length), so if you can get pliers or similar on it, you should be able to compress it and pull it out that way. Looks like this:
1 - 2 of 2 Posts
