Hi all. I have some aluminum mx bars and I’m thinking about installing them on my CL450K5. They are Tusk T-10 Aluminum 7/8”.
Here’s a link:
https://www.rockymountainatvmc.com/p/947/12330/Tusk-T-10-Aluminum-7-8"-Handlebar
I’m just worried that drilling them for routing wiring is going to compromise them to a point that they are not safe. I don’t get too wild on the bike and if the holes are minimal and clean would they be okay? Here’s a couple of pics.
They look as if there is about 1/8” wall thickness so my guess is you could go ahead carefully, I would drill a succession of small holes and then open them up with a dremel cutting disc finishing off by relieving the holes with a chamfer. Don’t forget the hole for the locating pin either. The bar ends shouldn’t be a problem nor the Centre hole where the wires exit because it will be supported by the bar clamps.
Good luck
Nigel
I wouldn't worry about it.
Reactions: Alan F.
Rounding off the sharp edges is important. A sharp edge creates what is known as a stress riser, which is where cracks can start. Burnishing the edges away helps reduce the chances it will crack.
Will you be able to fit the wiring into the ID of that tubing? There will be significantly less room with that wall thickness.
