Well, you will want number drills, but METRIC ones..... a 70 jet is .70mm....You could convert to english measurements and use the appropriate number drill.... Somehow, I'm not believing a #70 drill is exactly 70 anything....(.70mm or .70")
Number sizes came from the old wire size, when making wire they would force the hot wire through a die, and yes, the first die size was (in the US) #0000 (not quite 1/2inch) so to get finer wire they needed to use ever decreasing sizes all the way down to #80 die. As the technology advanced they were able to use larger die's as a starting point, so the letter sizes came about starting from A, and working up to Z the largest. 0, 00, 000, 0000, A, B, C, D etc
Now to completely screw things up, there is at least 4 different wire gauges based on different principles and maths and of course the French have their own. But for you 'Mericans the one above is yours
I have worked on Aircraft all around the globe and once work in a hanger restoring vintage military aircraft, that had a Mitsubishi (JIS metric) Cessna (US Imperial) Spitfire (Imperial, Whitworth) and Dassault Mirage (french, Metric) which gave us a HUGE selection of tool and problems!
The British wire gauge (or SWG) is still used by some manufactures to give the thickness of sheet and of all things guitar strings.
Along came the Imperial and Metric systems and the number size system died out, well sort of.
Back to the topic
... strangely :? #70 is 0.0280 of an inch or if my maths are right 0.07112mm, but sadly still not the right size.
Japanese bikes, think metric for everything
Don't get me started on JIS v DIN v ISO :x OR bolts
