How does overflow tube seem? Could it be leaking at the base of tube in the bottom of the bowl? Leaks while running?
Definetly not coming out from float bowl gasket or side of carb?
id check your float valveso you know it wont go into the engine to be safe.
maybe wrong kind of drain plug? There are slightlydifferent styles for different carb models.
