1 - 2 of 2 Posts
I'm restoring a '74 CB360. I put on a set of drag bars to see how the riding position would be and liked it. Porblem is, the mater cylinder hits the tree. Is there another master cylinder/lever that will work?
Anything that will clamp to a 7/8" bar that you can get an appropriate brake hose for will work, you just have to make sure you're moving at least as much brake fluid with your new one. I've seen people using modern radial calipers on these old bikes and they work fine. Don't have any info on particular models, though.
1 - 2 of 2 Posts
