Struggling with an issue where the bike starts easily, rides fine for about 2-3 minutes. Then its idle drops and it wants to stall. At this point, it wont rev out. Hangs at about 2k.
I’ve done everything I can think of…
-Checked timing (points, valves, etc…)
-Replaced carb boots
-rebuilt top end with new rings
-put on oem air filters
-checked gas supply
-reset floats
I’m starting to wonder if it is battery related because the battery will frequently lose charge and need to be charged after one of these test runs.
Regulator seems to put out 13.2v when running.
I’m lost here. Any tips?
-checked gas supply
-reset floats
