Hello,
I recently had to do a partial rebuild on my CM400T engine, now i am putting it back together and was wondering since there is no gasket that goes between the lower cases (crankcase) do i need to use a sealant on them when i put it back together? and if so, is there a certain sealant i should use?
Thanks,
Matt
Yes. Threebond or Hondabond.
Do not use a silicone sealant or gasket goo. Only what is stated above. There is one other place for the Hondabond and that is the mating surface between the rocker boxes and the head. All this is covered in detail in the manual.
Also don't cake it on either, you only need a thin layer. If you use too much itll smush out and get places you don't want it to
