Now that I've finished with the CD175 engine upgrade project (CB200 cylinders and bottom end with a CD175 head, see also CD175 upgrade to 200cc, 12V, electric start, 5 speed gearbox ) I can move on to another project I've been looking forward to, putting a disc brake on the CD175. (I call it the CD200 now).
The CD175 stops "okay" with the small, single leading shoe front brake it came with. But, in some panic situations you feel like you're about to snap the cable. It takes a LOT of force. A twin leading shoe brake would be an improvement. The mechanical CB200 caliper and disc would be an improvement. But also why not go crazy and put a modern disc and caliper on?
Thoughts going into this:
I'll try to use a CB200 wheel and hub first. It has a higher likelihood of the axle diameter matching up, and the speedo drive being the same.
I'd like to convert the CD175 to 18" wheels anyway, so the CB200 wheels would be a good fit. I'll do the rear wheel as well.
I might use a remote master cylinder so I can retain the CD175 handlebar controls. I might have to tuck this behind the headlight shell or maybe under the battery or somewhere.
I'll plan on welding mounting lugs on the fork leg, not trying to use CB200 forks or similar. I want to retain the CD175 chrome fork covers.
Some risks:Speedo drive might not fit up properly. I'd rather not use an electronic speedo or anything, I'd like to keep it original. If I move to an 18" front wheel then the speedo will definitely be off a little. I might repaint the dial if it is too far off.
Welding lugs on the fork leg might be a disaster. I won't do, I know a coded welder that I have used on other projects.
Bike is still up on the table from the engine project and I won't be riding it in the UK cold, so now is a good time.
