Hello to all. I was recently doing some work (changing the gaskets and seals) on my CL160 and I found that the cylinder sleeves came out a lot easier than I had anticipated. I assumed these sleeves had to be press fitted or at least take more force to move as freely as it did. My only question is whether this is a bad or normal thing. They are in great shape but if they need to be replaced then so be it. Thank you.
You don't press them, just heat the cylinder and they drop in. They normally are a pretty tight fit at room temperature.
Reactions: Tim Allman
