Seems like it would be straight forward, but is it? Transmissions the same? Just change the clutch cover and add the kick starter?
Any insight?
Thanks in advance...
You may have to change your lower crankcase. The lower case is what hold the kickstart "ratcheting" mechanism that engages with the transmission when you kick the kick starter. I cannot say for sure tho.
-Dan
i realize this thread is old but i was wondering if u went through with the conversion. ive been thinking about performing the same addition to my 400t.
I've got one engine with and one engine without and the case guts are different. The one with has a shaft that goes into and behind and through the inner case, the one with out has none of th eparts oyu need to do this, or the shaft that sticks through the inner case :(
