I have a 1972 and 1976 cd175 ‘s are their any parts which are compatible from other bikes that can be used
I need throttle, clutch and front brake cables
Thanks rustym
I suspect that the clutch and front brake cables will interchange, from almost any CB or CL 175......SL 175 versions might work as well......
This is easily verified by comparing part numbers from the various fiches (CMSNL is a good source to check)... Same part number=same part...(first eight digits match)....
For the throttle cable, you will likely have to get either a CD single cable from another year CD model, find a "dirt" bike throttle cable that has the same "ends" and overall and "free" lengths, or manufacture your own....(I have often made small bike throttle cables from bicycle derailleur kits)......OF COURSE, there's always MOTION PRO if you want one specifically made up for your bike.....
I'm in the UK, restoring a US import CB350 and need a 1 into 2 throttle cable does anyone know of a source here in the UK or will I have to import ont one from the US?
Terry
