You are liable to get anything going to autozone...i keep my purchases to very simple things there .....not that the staff is bad but alot of the employees never worked on anything at all before working there. When i was coming up and you went to a parts store the guy at the counter was dirty half the time from working on something in the back room or out back....lol.krukster86 said:Black spark plug wiring is now back in stock!
Funny thing is that I went to a NAPA and an Autozone a couple days ago they thought I was speaking gibberish when I said I just wanted some spark plug wire...
ok cool that would be greattbpmusic said:I'll post a pic tomorrow, ok??zx12ryder said:hey tbpmusic....you got a pic of where you mounted your condensor? i just did the same mod on my bike and would like to get the best idea for mounting it.(the condensor)
Just happen to have the tank off, working on the left carb.....
Yep. that's about it. Connect to the coils on one of the bolts that pass through the frame.joshuatyler1 said:I'm new to this whole electrical scene. How do I go about doing this ground wire? Literally, just get a 10 gauge wire and connect it to the negative terminal of the battery and then to the condenser? Where do I connect it to the coils and the other parts? Just on the base or on one of the wires. !
Josh
Everybody deserves good spark.......Brown Bomber said:Just did the coil replacement as described today, worked great. It took a while, but i put the condenser between the coils. Tight fit, but worth it.
Thanks,
Allen
