Are you saying you have the bike wired this way with the coils connected directly to the ignition switch and not through the kill switch? I could see the potential for some voltage spikes but would contact Pamco to get their opinion. Expensive piece to fry.
Im re wiring it correctly now (never tried to start it the other way)
Sent from my SM-G930V using Tapatalk
I would feed every thing off the kill switch, you know it will stop and you don't need to risk heating up parts with stray voltage.
Reactions: Lost_Cause
I have found voltage drops from a dirty kill switch, the ignition switch and connector, in the headlight bucket connections and from a partially broken wire in the wire harness. The voltage should be checked at the coils and should be close to battery voltage. Be sure also to check under load, ie running at higher rpms.
Discussion Starter #7
Thanks! Will do !
Make sure you have good grounds especially if you have done some painting on the frame. The coils ground through the frame. Also the ground strap at the engine needs clean metal to the frame and engine.
Discussion Starter #9
Oh man, this is why I'm on here!
The coil mounts i welded are painted and the coils are in rubber washers to avoid vibration!
Ill add a strap! Thank you so much for the heads up.
