So I have the shocks and rear wheel off my '83 CM450e and I'm looking to increase the ride height as much as possible in furtherance of my scrambler build (without switching out the spoked 16" rear wheel). What is the tallest shock I can put on it still without hitting the swing arm travel limit? I know a 340mm will fit, anything taller? With consideration to taller shocks, what is the tallest off road tire that will fit on the 16" rim? I know I need to keep it around 120 (maybe 130) to keep from rubbing the chain. I pulled the chain guard off and probably won't be using it.
Thanks in advance!!
Thanks in advance!!
