I finally got a rim to match my front. A 16" spoked off a CM400E
However it arrived missing a valve stem. I thought it would be easy to pop a generic steel or rubber one in, however the hole in the rim is about 8.2 mm or .33", much smaller than everything at the auto parts store.
Is there a specific valve stem for these rims, or do people drill them out to accommodate more common valve stems?
Thanks
Doesn't a spooked wheel get an inner tube, not a valve stem?
Yep, my 81 CM400E specs a tube becaused of the spoked wheels.
Ledzep, you need a tube, this is the one I bought when I replaced the tires on my bike. Since you said it was a 16" rim, I assume it was a rear wheel rim, as opposed to the 18" one on the front of the E models. Make sure it works with what ever tire size you end up going with.
https://www.denniskirk.com/irc/16-in-inner-tube-with-chrome-stem-t20035.p54265.prd/54265.sku
Ahh!! A tube didn’t even cross my mind as Its being swapped off a 450 nighthawk which was tubeless. Talk about a one track mind.....thank you!
