Hey everyone,
I'm in the stage of collecting parts for my rebuild. I'd like to swap from the stock mag/disk brake to as spoke/drum brake.
Why? I like the look of the spoke, and it matches my current rear wheel. And, by converting to a drum break I can eliminate the master cylinder on my handle bar cleaning it up a bit.
Question - Are there wheels from hondas that respect the look, and bolt in (other than the CM450E)? I've searched the forums and didn't really have luck.
Cheers
Dave
It appears you have a CM450C (you have a tach) which a PO has swapped out the rear wheel from an e-model. Finding a front end from a CM400/450 e-model will be your simplest option. They are not exceptionally hard to find. At the least you will need the slider for the left strut.
Thanks J-T, I'll keep an eye out. Any idea where I can find a single spoke? there's one missing on the rear
