Hi all! I'll be hitting the introduction thread here pretty soon, but right now it's a little late. I'm at the very late stages of a CM450C restomod, and I've found that while the starter works and the engine kicks over, it only does so on rare occasion. I'm getting a good connection to ground from the 15v and 7v fuses all the way up to the ignition, but no lights, and no signal to the starter solenoid. For the most part. On my second or so attempt, nothing happened for a good minute and a half after I'd released the button, then the starter kicked the engine over once (giving me quite the scare). In trying to diagnose the issue it's happened several times since, but nothing consistent. The entire time it was on it's center stand and the handlebars were never moved. The yellow/red wire from the start button yields no signal most of the time, nor does the black wire in the red connector inside the headlight bucket, but I do get good signal from several other lines in that connector.
