I was changing the bulb to same bulb and i removed the headlamp . I saw an unplugged green wire and i saw another wire with mated connectors. WOOPS One was green the other was brown. Bike is dead. HELP. Would love a text if yippy know what the issue is names Billey 6238001319
Remove your left side cover you will find your fuse box
Green is ground, Brown is taillight/park light. There is a spare Brown in the headlight bucket and not all Green connectors are used.
Be sure to use metric fuses, SAE auto fuses are too long to get a proper fuse connection.
