In first gear my power deliver sometimes "pulses" sort of like a fuel starvation, but in high gear in doesn't occur. it occurred to me I've never inspected the drive system...not even sure if its a belt or what. Im off to study the manual..
Any constructive input appreciated
Clay
[email protected]
I'd look at the chain and sprockets first. You'll need to remove the chain to fully inspect it by rotating each link full travel to insure that they all move freely. Sprockets should have a squared tip if they're still good, pointed tips are worn out.
I just got my CB400A, and it does about the same thing. From experience, though, I can suggest it's most likely the carburetors. I found a carb float that was bent way off its normal level...
