On the pilot gauge of the 1982 CM450A that I just restored there is a strange issue with the neutral light lighting up when in second gear. The light is normal in neutral and is off in first gear, yet in second gear both the second gear light and the neutral light come on. I will start to trouble shoot the circuit, yet wonder if anyone has some suggestions on what is happening or has solved a similar issue.
Discussion Starter · #3 · (Edited)
Ok, I did have the switch out of the upper case and will have a look at that too. There aren't a lot of parts in that circuit, so it should be that or a connection.
It was the ground wire in the harness at the connector it was flakey and needed to be resoldiered to fix the issue. The FSM has a test procedure for the connector and I discovered the intermittent wire issue while testing it.
