I have a bunch of parts from an '83 cm. Much of it is small hardware, bolts, wire hangers, spacers, speedo gear, other widgets and gadgets. Good gauges, forks, a nicely painted clean tank (silver) with matching front fender and ignition/key set, foot pegs, frame parts, good wiring harness, electrical components, filter box and velocity stacks, signals, hydraulic system, controls, switches. I have a set of side cover tabs that were cut off the frame if anyone needs them.
Below is the tank but I am not going to post pictures of all of the stuff. If you are looking for hardware or other bits send me a picture and part name, I'll see if I have it.They are good parts.
I will sell parts for a fair offer (newbies note, extinct parts are not given away). I will ship anywhere for cost. The tank and ignition are a package.
306404
I know you had this up a while ago, but is the tank and other parts still available?
I also live in Ontario (Toronto)
81 cm200t Twinstar minor rebuild
Is this still being parted out? Do you happen to have the center stand, return spring and plate?
Hi there from BC. Looking for 1 or 2 carb insulators. Must be off of a cm450a. Would have CM1 embossed on outer radius.
Please reply if yours is an automatic, cheers... Thorinn
